TwinTurbo.NET: Nissan 300ZX forum - Re: TT rear and 2+2 front are the thickest OEM options.
ctheobal
on March 08, 2017 at 4:09 PM
TT rear and 2+2 front are the thickest OEM options. (n/m)
posted by Bernie (NoVA)
on March 07, 2017 at 10:56 PM
Would you say 2+2 front and TT rear with adjustable links would be adequate to reduce roll since I don't track the car? Would be a lot cheaper!
Sway bar suggestions
ctheobal
09:14:30 03/07/17
Not sure what you have
-Grimm-
10:09:47 03/07/17
I have a stock TT and stock sway bars (n/m)
ctheobal
11:16:58 03/07/17
I recall SPL recommending to run upgraded bushings for the
PiotrC70
17:04:19 03/07/17
thanks for the suggestion.
ctheobal
17:24:36 03/07/17
22:56:02 03/07/17
non adjustable :( (n/m)
vorpalZ
23:19:24 03/07/17
Darn, had it backwards. Theyre adjustable if...
-Grimm-
10:03:59 03/08/17
2 things with the adjustable endlinks...
vorpalZ
16:11:48 03/08/17
Re: TT rear and 2+2 front are the thickest OEM options. -
ctheobal
16:09:28 03/08/17
I use them as a budget upgrade option but prefer aftermarket (n/m)
06:01:26 03/09/17
Stillen & Suspension Techniques are interchangeable. (n/m)
10:33:56 03/07/17
thanks Bernie. I will check them out. (n/m)
ctheobal
11:35:28 03/07/17
Interesting...bc I have a set of ST and the Stillen bushings
ForceFedTT (SoCal)
14:53:19 03/07/17
Interesting indeed (n/m)
ctheobal
17:26:13 03/07/17
True - but you have to measure any bar you buy bushings for.
22:53:32 03/07/17
Thx, Bern. Was wondering if I was the only one who
ForceFedTT (SoCal)
19:18:05 03/08/17
Suggest you research hollow vs solid sway bar
Mr.Stacy
08:44:47 03/08/17
100% disagree. sway bars are a great bang for the buck! (n/m)
genic
14:08:57 03/08/17
Someone should cut open and measure the hollow ones
not4resaleZ
07:03:08 03/09/17
